Thread: 3 last questions
    buddywiser's Avatar
    Morgantown, WV
    98
    3 last questions
    1. Should I take out my cartridges or leave them in the filter through the winter?
    2. I have a heat pump (Heat Siphon) and I noticed a little standing water in the bottom. Is there any danger from this freezing? Should I just pour a little RV antifreeze in there to be safe?
    3. My water level is currently below the jets. I have a mesh cover. Now over the course of the winter, I expect rain and snow meltoff to bring the water level up over the plastic parts. This is my first closing, but I opened last year and the water was around normal summer levels, so I'm guessing this is what happens over the winter. I feel I've done everything correctly as far as the skimmers and lines go. Would I be safer or just wasting my time if I checked the water level every 4 weeks or so and drained it below the jets again if it was coming up?
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
    Jun 2007
    Poughquag, NY
    217
    I live in NY and just let the water level slowly rise over the winter/spring. I really don't think there is any reason to drain on an ongoing basis. The original drain is to get the water level below the skimmers and returns so they can be blown out and (possibly) have anti-freeze added.
    If you decide to drain, make sure there is no ice on the top of the water. It will cut your vinyl no doubt.
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
