Thread: Intelliflo VS or Whisperflow, what do you think?
    Hi there, new to the forum and to owning a pool. Just bought a house, don't know much about the existing system. Here's what I know, 17K inground pool with 2" plumbing, an auxiliary pump for the sweeper and a coil solar system on the roof. The main pump needs to be replaced. Best guess, I expect to be in the house for 5+- years.
    I'm trying to decide between the new Intelliflo VS and an Intellitouch or Suntouch control system (I'm told although the Intelliflo has a built in timer because of the auxiliary pump I need the Intellitouch or Suntouch control system) Total cost not including install is about $1300
    or the Whisperflow (2 speed, 1hp) with a Intermanic 3 circuit digital timer.
    Total cost not including install is about $800
    Which setup would you recommend. Any advise is welcome......thanks.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Intelliflo VS or Whisperflow, what do you think?
    Topshelf, it depends on how much $$$ your willing to spend. Also what are your electric rates per kilowatt hour? This will determine how long you will recover your cost. Can't go wrong with either, just make take longer to pay for. What's controlling your booster pump now?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Thanks for the reply. Kwh is about .15c per hour. Also, with the Intelliflo system I can get a $100 rebate from Electric Company. Best guess is I will be in the house for 5+- years. Wondering if the Intelliflo system would pay off versus the 2 speed Whisperflo? (I've seen the calculator on Penair's site, but they only compare the Intelliflo to an "existing" 1 speed pump)
    Don't have access to the house for a few days, so don't know exactly what controller is on the booster pump now. Whatever it is, I'm told it was installed 8 years ago.
    mas985's Avatar
    Pleasanton, CA
    11,741
    In my signature is a link to "Pump Modeling Tools" that contains a spreadsheet that allows you to do your own cost/benefit analysis. But from experience, at $0.15/kwh, it is very unlikely that the Intelliflo will pay for itself over the life of the pump.
    Mark
