Thread: losing prime when pump is off
    Apr 2010
    Central NJ
    227
    I'm losing prime when the pump is off. it doesn't happen immediately, it takes a couple of hours. I also hear a noice when the pump is running, and I don't know if it's related. It sounds like dirt is running thru the multiport vavle. I don't have air in my pump strainer basket, so that seems to be ok.
    any ideas?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: losing prime when pump is off
    You have a small leak in the system that allows air in to break the prime. It's not a huge issue but, if it really bothers you, you can try the leak detection tricks in pool school and report back.
    Luv& Luk
    -Ted
