Thread: cloudy water
    cloudy water
    need help with a cloudy pool. i did an overnite fc loss test and lost less than 1 ppm fc. all other test normal.
    fc 6
    cc 0
    cya 40
    ta 8
    ph 7.8
    vac and brushed pool 3 days in a row. have had no problems last two years using bbb. can barely see bottom whan standing in pool.
    24 ft. 52 in. deep above ground
    hayward sand filter
    new pool owner/new bbb believer
    Feb 2008
    Denton, TX
    5,061
    Re: cloudy water
    Just to be certain, your TA isn't 8, but 80 right? What kind of test kit are you using? Also, out of curiosity, can you post a CH?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: cloudy water
    Yep, anytime someone mentions cloudy, we wanna see a CH#.
    Looks like you have completed two of the three steps to be done shocking.
    Keep shocking until the pool is clear, but lower your pH first. See red info in my sig.
    You're done SLAMing when:
