Thread: From a local, repsected pool dealers webpage...
    Q: How much is too much stabilizer?
    A: A common myth in the pool industry claims that too much Stabilizer (Cyanuric Acid, CYA) in pool water "locks-up" the free available chlorine residual. Chemically, this is not accurate. The free available chlorine residual kills microorganisms with CYA levels up to 500 ppm. Minimum CYA level is 30 - 40 ppm, acceptable is 30 - 200 ppm for residential pools.
    24' AG Doughboy w/ 5'8 dish bottom, CWII DE Filter, 1.5 hayward 2 speed pump, Aquatrol SWG.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: From a local, repsected pool dealers webpage...
    Thanks!
    Sure, they say that up to 200 is fine, but they're also the ones who sell the chems to 'fix' the problems 200 ppm cya can cause
    Luv& Luk
    -Ted
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    At least that explains why those folks walk out of the pool store with a case of powdered shock under each arm.
    Jun 2010
    74
    Can I ask what your source is for this? British Columbia health authorities recently started testing for CYA as part of their inspections due to the problem of "chlorine lock". They close your pool if they find CYA over 80. Not a problem for me, since the only time I see CYA that high in anything is hot tubs using trichlor pucks, and usually by the time I reach 80 CYA it's due for a drain anyway (due to high TDS).
    * Responsible for the operation of 21 semi-private pools and spas at 11 locations, varying from 1,900L to 20,000L spas and from 13,000L to 200,000L pools.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    I just did. At least three places have the frst line verbatim. So the source is likely one of their vendors..... Bioguard is my hunch.
    If you can handle some semi-advanced chemistry, you should take a look at this post, which explores the chlorine/CYA relationship. The sanitizing ability of chlorine can be maintained as the CYA level rises as long as you proportionately increase the chlorine level. Of course, at high CYA levels various side effects make that impractical.
