Thread: New guy, old pool, lots of questions.
    Hi everyone. I love this site, and really like the idea of a bbb method. Well, I just bought a house (my first one) in tucson, az, so a pool was a must have. Everything was great until we closed on the house and on final walk through, the po let the pool go. I have been trying unsuccessfully to clean it and get it going.
    Heres the situation..
    15000 gallon pool, swg (hayward swimpure), green and cloudy for probably 2 months now.
    Itested the water and got ph8+, ta 110, cya 60, tc 0, nacl -2600.
    I put in 20 oz acid. 80 lbs pool salt. 3lbs hth shock. 4 gallons bleach (6%). I run the pump for as long as I can..but I'm not fully moved in yet, so I'm afraid of the filter pressure building up..i backwash a few times a day (sand filter) when I can.
    Now, chlorine still low @2. Ph 7.8, everything else is essentially the same.
    The pool has not visually progressed at all..still green and cloudy..i can see the second step (barely). What am I doing wrong..any suggestions would be immensely appreciated.
    -John
    13k gallon IG gunite pool
    Jandy 2 speed pump
    Jandy cartridge filter
    Stenner Pump and tank
    Re: New guy, old pool, lots of questions.
    Welcome to TFP!
    I would take this moment to lower the PH again. Then you need more chlorine.
    Shocking is an on-going process. You keep adding chlorine to bring the FC level back up to shock level until the FC level will hold overnight. If you haven't already, take a look at How To Shock Your Pool in Pool School.
