Results 1 to 7 of 7
Thread: Chemical Order
    SPrater1270's Avatar
    Jun 2011
    Maud, Texas
    25
    Chemical Order
    This year, I started with pool store instructions and, after a frusterating week, found this place. I'm just wondering, for future refrence, what order should different chemicals be added in? Also, what chemicals have to be added alone? I know this is prettyr vague, but just wondering....
    I usually have to add ph plus, cya, calcium, alkalinity plus, and, of course, shock.
    24' round AG, sand filter, 1.5 HP pump
    Re: Chemical Order
    There are a lot of special cases. A simplified list is something like:
    If TA is below 50, raise TA to 50
    If PH is way out of range, adjust PH
    If CYA is way too high, lower CYA
    PH
    CYA
    Raise TA if needed
    CH, adjust CH on it's own day
    Lower TA if needed
    Jun 2011
    Maud, Texas
    25
    Re: Chemical Order
    Thanks! I've always just did what the pool store said - and bought their stuff.... But their solution to anything is to buy more stuff!! I'm going to buy a good test kit and follow advice from here!!
    Re: Chemical Order
    Quote Originally Posted by SPrater1270
    You will be surprised at just how fast it all begins to make sense. Then you will be amazed at how easy it all becomes. Then you will wonder how other people can stand to keep their pools the way the do when it is really not that hard to have a totally clean sparkling gem of a pool. And, weirdly, it is cheaper.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Chemical Order
    Quote Originally Posted by anonapersona
    anona, exactly
    You're done SLAMing when:
    Jun 2011
    Maud, Texas
    25
    Re: Chemical Order
    I am beginning to understand better already. I wish I had found this site years ago!!! (or even knew to look for it!!) I could have saved lots of time and $$$!!!
    Jul 2009
    London and France
    574
    Re: Chemical Order
    PH
    CYA
    Raise TA if needed
    Lower TA if needed
    I always start with CYA as so many people are over stabilised if water needs replacing why waste good chemicals.
