Results 1 to 8 of 8
Thread: Which location is better?
    May 2011
    Bensalem PA (Philly Suburbs)
    82
    I am looking to install my pool in the next week or two (sooner the better of course). It is a 38' by 18' oval above ground pool with A braces (so I can cut the straps and made a deep end). I plan to build a deck from my backdoor (which is above ground) to be level with my pool. My problem is deciding on a final location, I have 2 spots that I could do.
    One is in my backyard lengthwise 12' from the fence (10' is required, so 12' to be safe), with the 18' end next to my existing porch. I'd have to cut down a nice pine tree to put it there.
    The second option is on the side of my house, where I currently don't really use the yard. I have like 33' between my house and the property line, so I think I can squeeze it in next to my house. I'd build a deck across the back of my house to the end of the pool, or I could cut down the giant tree and extend the pool out so the deck goes to the side of the pool a little.
    On the side of my house, I can have more privacy with a fence or bushes/trees whatever, but it's more enclosed. Also would have trees overhanging it, I'm not sure if I'd rather the shade in the summer, or full sun in the backyard during spring/fall.
    Since I know everyone likes pics, here are some I just took of my backyard: http://www.facebook.com/media/set/?set= ... eTheater=1
    Any recommendations which spot I might like best or regret more in the years to come? Or any things I should consider for either location?
    18' x 38' x 52" oval AGP with 6' deep end (foam on the walls, preformed coving, and Happy Bottom floor padding)
    Pentair Optiflow 1 HP 2 Speed pump
    Pentair cc200 cartridge filter
    Pentair UltraTemp Model 110 BLK 108,000 BTU Heat Pump
    2 Intex SWG's (copper unplugged)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Which location is better?
    If you want headaches...put it under all those trees. I'd take that pine down in a heartbeat. I think you'll end up wanting more room around the pool any way.
    May 2011
    82
    I am leaning towards putting it in the open... uses up a lot of my backyard, but seems it will be less problems both installing and in the long-run.
    Anyone else have comments/suggestions?
    I'd imagine that without full sun your heating costs would be significantly higher.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Feb 2011
    Petaluma, Ca
    665
    I know in my area, full sun is the way to go because our temps are usually in the 80's, if it was alot hotter shade might be nice. I'm glad there are no overhanging tree's at my pool, enough stuff blows in as it is and the trees are approx 30' / 50' away.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Sep 2009
    Greentown, IN
    914
    Being in Indiana I prefer that my pool be in the sun to gain heat in the pool, but hope to get a canopy of some kind over part of the deck so there is some relief from the sun during the heat of the day. I suspect in Pennsylvania you may find the same to be true.
    Where my pool is placed, we do get some shade in the evenings from trees which is nice during the hot part of the summer, but during spring and fall we could use the warmth of the sun. Canopies and umbrellas can be moved, trees are a little harder to manipulate
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jul 2010
    Mickleton, NJ
    229
    Hi South Jersey here. We are from Philly originally. Anyway, I also vote for full sun and also somewhere you can sit on the deck and enjoy the view of the water.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    May 2011
    82
    Seems like everyone here (and my friends elsewhere) all agree that full sun is best, and fences or shade can be added later if wanted. I put in the permit application for it there, now I just have to wait for the permit to be approved, and the pool to actually get delivered... just hope it gets in in the next week, or else it will be mid-July before I'm using it...
