Thread: Clearwater LM2 Flow Sensor Not working
    So I noticed today my SWG, Clearwater LM2, flow sensor is not working. If I turn the system on and have the pump off with absolutely NO flow the low flow light does NOT come on and the unit just keeps producing and slowly builds up gas in the cell. I recently had to switch some control features on my system and now its possible for the SWG timer to get "out of sync" with my pump timer. I am worried that this safety feature isn't there and I will burn out my cell in the event of timer sync issues. I am trying to avoid buying a whole new integrated control system for now.
    So my question is How does the flow sensor work on these unit and is it replaceable without changing out the whole cell?
    33'x21' In-ground (23,000 gal) - 8' spa raised 18" with 8 jets | Filtration Jandy DE 60 | Sanitation Aquapure 1400 SWG | Pumps Intelliflo VS+SVRS 3.0HP & Jandy 1.5HP stealth water feature pump | Heating Jandy LRZ400 | Lighting Jandy LED Spa (1)/Pool (2) | Coping Tennessee Crab Orchard & Moss Rock | Finish pebble sheen type (riversand) Tahoe Blue
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Clearwater LM2 Flow Sensor Not working
    Sorry I can't help, but it does sound like a problem that really needs fixing.
    Check the sensor wire between the control unit and the cell and make sure the wire isn't damaged or cut.
