Thread: Intex SWG question
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Intex SWG question
    I have an Intex SWG, and the owners manual says to keep the pump running for an hour after the SWG shuts off. Is this necessary?
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Re: Intex SWG question
    You absolutely want the pump to run for a minute or two after the SWG shuts off. They say an hour because timers aren't all that accurate, can often only be set in units of an hour, and they want to make really sure the pump doesn't turn off first.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Thanks! I've been running the pump for about 30 minutes after the SWG shuts off. I just wanted to make sure I wasn't going to cause any damage to anything.
