Thread: Advice before I sign a contract....Oldsmar, FL
    May 2011
    Oldsmar, FL
    20
    Interviewed a couple of builders and have received some quotes. Please provide me some constructive criticism.
    Yeah, I promise pics....
    16' X 28' gunite pool, sport style, deep in the middle, generally a rectangle with a bump out of one corner and a bump in of another. 4' Sun shelf/Baha step on one end swim out in the far corner. Coping and water line tile included. Krystalkrete finish inc. I gotta pay for fancy mosaic tile for the bottom, but installation is inc.
    Excavation and dirt removal included
    Electric from panel to pump inc.
    Plumbing to pump inc.
    Salt water generator
    1hp variable speed Hayward pump with cartridge filter.
    1 skimmer, four returns (one is a bubbler).
    Non robot vacuum (Navigator)
    Auto overflow What does an auto fill cost?
    1 color LED fancy changy mood ring light
    Price is a bit under 20K. Anything I'm overlooking? I'm gonna ask what it would cost to make the pool 30' or 32' long. Any idea what it should be?
    They're willing to have the excavator scrape the deck site for me and then I'll have sand and pavers delivered. I can purchase end runs of pavers by the pallet for about a dollar a square foot and install them myself. I'm also planning on installing about 144' of 6' vinyl fence myself.
    Thanx in advance
    15K gallon inground pool. Krystalkrete finish, 1.5hp Hayward pump, 120 gpm cartridge filter, Polaris 360 cleaner.
    Nov 2009
    Indialantic, FL
    323
    Re: Advice before I sign a contract....Oldsmar, FL
    Quote Originally Posted by onerailunder
    They're willing to have the excavator scrape the deck site for me ...
    My main advice is get it (and any other promises) in writing - some years back I first heard the old saying, "If it isn't in writing, it wasn't said". Most every PB I dealt with didn't want to put much detail into their contract. I went back & forth with my salesman, and sure enough during the build the PB wasn't going to do something I asked about until I could show paper between his salesman and me. I think there is a tendency for salesman to say almost anything to make the sale, and hope the job goes well enough that the build crew won't mind picking up the little stuff, but if the job goes bad, you need the paper in hand.
    My pool is 36' and I definitely need the two lights I had installed, if you do go longer you might also want to think about another light.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,091
    You might also want to consider putting in a footer in case you want to screen it in at a later date and do not skimp on the size of the equipment pad as you may want to add other equipment in the future like solar and heat pump. Get the plumbers to pre plumb for these. Definitely 2 lights. From what I read you may not be happy with the size of your baja shelf. IMHO if you are going to have one it should be a lot bigger and don't forget umbrella sleeves.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Nov 2010
    Calera, Al
    271
    X2 on a bigger tanning shelf and more umbrella sleeves than you think you'd need. Your pool will be the approx size if mine and I do not think those numbers are out of line. Although you are in Florida and cost will vary with location. Ensure you have large final payment with the smaller payments as the build progresses. It will ensure the job is completed to your satisfaction and the builder does as the contract stipulates. Good luck and remember we love pics!
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    May 2011
    Oldsmar, FL
    20
    Thanx, I'll ask about a second light. Any idea what it should cost? Bigger pad for potential solar in future...check. I'll prolly discuss adding area to the sun/tanning shelf and see what it will cost. Yeah, lots of umbrella sleeves. I was actually thinking of adding a 4" sleeve for a potential basketball net, but I don't think there is any standard size for a post for a basketball hoop. I may just pic up a six foot long post and some pvc pipe that fits over it and fab it myself. I'm guessing 3' deep. Seems like I ought to do it while I'm doing fence post holes.
    maybe you want them to run electrical lines for receptacles or future lighting?? I dont know how far your pool is from your house.
    18x36 Kafco steel wall Vinyl liner pool.21,000 Gallons 8ft deep. Pentair 420 cartridge filter, Intelliflow pump, Pentair IC40 salt water generator with Easytouch control system. 2 skimmers, 2 returns
