Thread: AquaTrol & 27'x52" pool?
    FastCougar's Avatar
    Jun 2011
    Eastern Panhandle of WV
    99
    I know that it's recommended to get a 2x or even 3x capacity SWCG based on your pool size, but I have also seen people here talking about running the AquaTrol near capacity. I'm looking at my remaining budget (just bought pool & supplies, but have to get pump/filter & SWG) and it's starting to get tight if I have to get the AquaRite vs. the AquaTrol. Based on the Pool Calculator, if I fill the pool to 48" (I assume the 52" is total wall height, not water depth), that would put me at about 17K gallons ... the AquaTrol is rated to 18K. Thanks in advance for the advice!
    16,000 gallon 27'x52" Above Ground Pool
    Hayward XStream CC1000 Filter w/1HP Pump (hard plumbed)
    My Build Thread
    Aug 2007
    near the swamp
    806
    Re: AquaTrol & 27'x52" pool?
    have a customer with the same size pool and aquatrol, they have trouble keeping it chlorinated on the very hot days of summer, have to add liquid chlorine on those days
    It depends on where you live. In most of Texas or Nevada or anywhere really hot and sunny an AquaTrol wouldn't be enough for that pool. But in a shaded site in a Northern state it would be way more than enough.
    FastCougar's Avatar
    Jun 2011
    99
    Unfortunately, it gets pretty **** hot here and the entire yard is full sunlight ... Looks like I'm going to have to bite the bullet and charge the 40k AquaRite
    My Build Thread
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Thanks for supporting the site (check out the VIP Lounge)
    If you don't mind supplementing with bleach on the worst days, you could get by with the Aqua-Trol. A solar cover would also lessen the load on the unit.
    Luv& Luk
    -Ted
    FastCougar's Avatar
    Jun 2011
    99
    hmmm ... so I'm also looking at the CompuPool CPSC36, which is a very similar output rating to AquaRite T15 and it's hundreds less than the Hayward AquaRite ... hmmm decisions decisions.
    My Build Thread
