Thread: Chlorine level non-existent with SWG
    I have added chlorine stabilizer to the IG pool 24 hours ago & cleaned the cells in my Jandy Aquapure 700, then 6 hours ago I set the control panel to chlorine boost & still have no chlorine registering. The pool is still very clear, but am wondering how long it might take to produce chlorine?
    22,551
    Re: CHLORINE LEVEL NON-EXISTENT WITH SWG
    Post a full set of test results and how you got them?
    Took water to pool supply store and the results were:
    Free chlorine 0.0ppm
    total chlorine 0.1ppm
    ph 7.9ppm
    hardness 200ppm
    alkalinity 87ppm
    cyanuric acid 10ppm
    salt 4000.00
    So I added 4lbs of cyanuric acid 24 hours ago.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Please don't use all caps
    Good move on CYA...how large is your pool?
    Since FC is basically zero, you may need to shock...but before we can determine that you need to get the chlorine level up asap with liquid chlorine. SWGs are good at mainatining FC when there is enough CYA in the water and there is no need to shock. But to raise FC from zero, you want to do that quickly without taxing the SWG.
    Thank you for the help. I got liquid chlorine and the chems are perfect right now, but will give it another day to make sure the chlorine stays int he pool. Is it safe to assume that if it fully burns off, then I have an issue with the cells in the SWG?
    Re: Chlorine level non-existent with SWG
    If the pool can go overnight without losing any chlorine, with the SWG off, and then when you turn the SWG on it loses chlorine quickly, then something is wrong with the SWG.
