Thread: Raised calcium hardness and free chloring went to zero
    Everything was great except my calcium hardness. I added enough to raise ch from 100 to 200, and the free chlorine went from 3 ppm to zero in 1 hour.
    Is that common that calcium chloride depletes chlorine?
    I since added chlorine but was curious if anyone knew of whether adding the cal. chloride knocks down the fc levels?
    34000 inground gunite / plaster pool 6 years old with spa. De filter system using fiber clear.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Raised calcium hardness and free chloring went to zero
    Adding calcium chloride should not lower chlorine levels. I've added it with no change in chlorine level. Perhaps the particular calcium chloride you used had contaminants in it.
