Thread: Reverse Water Hammer
    May 2008
    Tallahassee, FL
    2
    After 30+ years of use, my system has developed a peculiar habit when the pump shuts down. The back flow into the skimmer is so violent that it knocks my skimmer basket out of position, or when I am running my Navigator it will push the hose out of the suction line. Anybody else have this problem or even heard of it?
    Petey
    21K Vinyl In-Ground, 37 years, Hayward 3/4 HP Super Pump, Sta-Rite 75 SF Cartridge Filter, GE Digital Timer, BB&B.
    Re: Reverse Water Hammer
    Welcome to TFP!
    That is almost always caused by air accumulating in the filter. Open the air bleed valve on the top of the filter and let air out until a steady stream of water comes out. If the filter fills up with air over and over you must have an air leak somewhere on the suction side of the pump.
    22,550
    Pretty common actually. You have an air leak, and the air is getting in your filter. When you shut the pump off the air blows back out of your filter causing the skimmer basket to launch out of the skimmer.
    Common places to have an air leak:
    The pump strainer basket lid. Clean, inspect and lube the sealing surface & o-ring.
    The pump basket drain plug(s).
    The skimmer weir not working properly. Sticking is a culpret.
    The water level allowing the skimmer to create a vortex sucking in air.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    I get some blow back when I turn off the pump, but the pressure (and a splash of water) goes out via pump basket lid. Instructions state to not over tighten and I never do.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    May 2008
    Tallahassee, FL
    2
    Thank you...I will begin the search tomorrow.
    Petey
