Thread: Above ground checking in with numbers
    May 2009
    Columbus, MI
    22
    Just checking in with my numbers above ground pool, living in michigan we just had 94 deg hot days,
    with the hot weather my FC was going fast, but now weather is low 70's, go figure
    but that is why my FC is at 9
    heres my numbers, any thought if I should change any
    FC 9
    CC 0
    TA 130
    CH 100
    PH 7.5
    CYA 25
    28ft round AG 52" high 18,500 gals, Hayward ASL cartridge filter, Hayward single speed 1 1/2 hp pump, 2-4 x 20 fafco solar bear heaters, TF100 test, BBB
    22,553
    Re: Above ground checking in with numbers
    I don't really see anything that jumps out. How are you chlorinating the pool? If you're using bleach your TA might be a little high but I wouldn't purposefully change it. It'll change as you adjust your pH and if you don't or rarely need to adjust that it's fine where it is.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    CYA is a little low. That's probably why you were burning through the chlorine. It acts sort of like sunscreen for chlorine.
    Pool Calculator says 37 oz would get you up to 40ppm. If it were me, I'd add 32 oz and leave some breathing room in case I wanted to use a few pucks later in the season while I'm out of town.
    May 2009
    Columbus, MI
    22
    yes using bleach, so far ph has been stable. I thought CYA was a little low and will bring it up to around 40
    thank you for the info
