Thread: ABG Season Startup in the UK
    Aug 2010
    UK
    27
    Hi
    Just starting up the pool with fresh tap water.
    the area in the South West of England has fairly hard water with relatively high CaCo3 levels.
    I have the following chemicals at my disposal
    Sodium Hydrochlorite 14/15%
    Dry Acid
    Stabilized Chlorine Granules 55% (with built in stabilizer)
    Calcium Hypoclorite Shock 65% min
    Ph is 7.3
    CaCO3 is 267 (Calcium hardness)
    Chlorine is zero
    I think we can assume CYA level is almost zero from tap water.
    Water Temp is 14C (fyi it was 12C out of the tap!!)
    Reading Pool School I need a week or so of stabilized chlorine to add CYA levels.
    As the CYA level increases to 30-50 I should revert to Sodium Hydrochlorite.
    Agree?
    and thanks for your help in my 2nd season.
    Intex Ultra Rectangular AGP 18*9*4
    Certikin hydroswim HPS .5hp pump
    Azur 15" Sand Filter (pentair)
    EGFM glass particles (10kg of 1-3mm and 25kg of .5 - 1mm)
    Calorex AW910 Heat Pump
    Re: ABG Season Startup in the UK
    Yes, switching to Sodium Hydrochlorite is a good idea once CYA gets to around 50.
