Results 1 to 9 of 9
Thread: Above Ground Pool on Concrete Pad ?
    waycar38's Avatar
    Jun 2011
    Boonville, IN
    2
    Hi, i was thinking about building a 30' oval concrete pad to place a 24 or 27' pool on. we are in the planning stages and wasnt sure if concrete would hard on the liner or not. silly question probably oh well. thanks !
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Above Ground Pool on Concrete Pad ?
    Were you planning of using a Gorilla pad or other foam padding between the concrete and the liner? And how would you shape the coves between pool floor and pool wall? What if the concrete cracks from freezing/thawing cycles?
    If you don't want the pool anymore in a few years, that big slab of concrete will be very much . . . there, you know? What would you do with it?
    I like the idea, I just don't know if it's an okay thing for an AGP.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Concrete is fine as long as you clean any debris off of it carefully before installing the pool. Having some kind of pad is nice regardless of what the bottom is made of.
    Jan 2011
    Riverside, CA
    352
    If you pour a concrete pad, you should probably wait at least a month before you install the pool on top of it. Ask your concrete guy...or someone else here...
    40x20 Free Form IG Pool (aprox 29,000 Gal, 140 Perimeter, depth 3'6"-7', Baja Shelf, 8x8 Free Form Spa) - Gunite Shell, Pebble Plaster Finish, Poured Concrete Coping - 3 Deep Heat Returns - Jandy LXi400 Gas Heater (400,000 Btu) - Jandy Variable Speed Pump JEP 2.0 - Jandy CL 600 Filter - HASA Liquidator - Jandy PDA 6 w/ Remote - 4x Jandy WaterColors Pool LEDs - 48" Gas Fire Pit - 6x Gas Tiki Torches - 12'x15' U-shaped BBQ Island (Firemagic Equipment)
    http://www.troublefreepool.com/new-p...ca-t28413.html
    waycar38's Avatar
    Jun 2011
    Boonville, IN
    2
    i am a concrete guy, thats why i want to use it. its very cheap for me.
    edgy28376's Avatar
    Jun 2013
    Harrison Arkansas
    10
    I am looking into this as well. What psi did you use? And at what thickness? How long did you wait before putting the pool up?
    INTEX 18'x48" Ultra Frame Pool (6700 gallons)
    Hayward Diatomaceous Earth Filter
    INTEX CS8110 Krystal Clear Saltwater System
    TF-100 Test Kit
    Hayward Skimmer
    edgy28376's Avatar
    Jun 2013
    Harrison Arkansas
    10
    Well got the pad poured, it looks GREAT! Almost a shame to put the pool on it. The concrete contactor used a fiber infused mix so no rebar had to be used. The wait time I was told was seven days as they pour drives they wait seven days for concrete trucks to drive on them. We ended up waiting 10 days since it was poured on a Tuesday. As far as being stuck with a concrete pad that's not the case here. Living in the Ozarks (the base of the Boston Mountains) nothing is flat and the soil is a rock mix. This left us no other choice but to cut out and erect a retaining wall to create a level area.
    TF-100 Test Kit
    Hayward Skimmer
    May 2014
    SW, MO
    58
    We've been back and forth on the type of pool we can do here. After careful consideration I think my dream of a IG is not going to happen with water levels and flooding. So like you guys I plan to do an AG on a concrete pad. I hate sinking that kind of money into a AG but it's the best option and I don't want it to be a temp pool, I want it to last. Round here that means putting it on concrete. Otherwise critters will just tunnel under and ruin your foundation floor. Keeping the pool level with our heavy rains won't be a worry either. We don't have a lot of rocks here so that part isn't a problem but the creek out back could be.
    Glad to see I'm not the only one with the concrete pad idea and that it works. If we ever decide to do away with the pool it can be turned into a huge patio with a hot tub or something so no worries there. No idea what it will cost since it will be a very large pad, will probably do a 30' round or a 20x40 rectangle pool but it will still be way cheaper than a IG would have run us. If we could even find anyone to put a IG in, living rural we don't have any local pool builders, have only found one dealer that will come this far down and they are above ground only. No one I know has a IG pool.
    Oh I figure we'll use foam on the concrete and then a cover so the floor will have some padding.
    edgy28376's Avatar
    Jun 2013
    Harrison Arkansas
    10
    I think you will be pleasantly surprised after it's poured. I know I sure was. Like do I really want to put a pool on it? Well I did and I know if we ever sell the farm (not) there is a nice patio area.
    TF-100 Test Kit
    Hayward Skimmer
