Results 1 to 11 of 11
Thread: Where do I start ???
    Jun 2011
    Shelbyville, Indiana
    11
    New to the Forum - the School is a GREAT read and very informative.
    Just opened pool and readings are as follows:
    FC - 1
    CC - 2
    TC - 3
    PH - 7.3
    TA - 250
    CH - 300
    CYA - 10
    Temp - 78
    Water color - green - cloudy - barely see shallow end bottom
    I traditionally use Trichlor for chlorine and CalHypo for shocking - after reading my School assignments, I certainly will consider changing my bad habits.
    My CYA appears very low, while my TA is very high and CH is high. - What should I address first, and what effect will it have on all of my other readings??
    I do not want to compound my problems, so am reaching out.
    Would greatly appreciate any input !!
    Vinyl Liner-24K-2 skimmers-bottom drain
    Sta-Rite sand filter
    Sta-Rite 1HP Pump
    Circupool RJ-45 SWG
    TF100 Test Kit
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Where do I start ???
    First, deal with the algae. See the article "Defeating Algae" in Pool School. Use bleach, don't use any more CalHypo. The latter is what drove your calcium level up so high.
    What testing method do you use?
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Nov 2010
    South Central Kentucky
    283
    As said above, read pool school. I would start by getting some stabilizer (100% CYA) and bringing the level up to 30. Add the granules by pouring into a sock and hanging in front of a return, or spread it out into two socks if you have another return or your socks aren't that big For a 24,000 gal pool that would take 64 oz. (weight) 67 oz. (volume) to get there. You won't actually be able to measure that number (from water testing), if you use the granules, for about a week, so just trust that your calculations are correct. After that, you need to bring the FC up to shock level. Shock level for a CYA of 30 is 12. You need to add 547 oz. of 6% bleach to get to that level from where you are now. Then you need to maintain that level until: your water is clear, your CC is < .5 and you pass the overnight FC loss test. Info on performing that test is in pool school.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Nov 2010
    283
    By the way, I got all of those numbers from looking at charts in pool school and using the pool calculator.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,989
    What test kit are you using? It will go a lot faster if there's no guesswork involved with the readings.
    Nov 2010
    283
    Of course, the info I gave above is only reliable if the testing was accurate. So, knowing where you got your numbers helps. We've all come to know, sometimes the hard way, that pool store numbers are not always reliable.
    Jun 2011
    11
    Quote Originally Posted by AnnaK
    I used the TF100 test kit.
    Sta-Rite 1HP Pump
    Circupool RJ-45 SWG
    TF100 Test Kit
    Jun 2011
    11
    Quote Originally Posted by joshs2000ss
    Great, thanks.
    At what time do I address the High TA?? I am currently at 250. So how do we address the issue without throwing all the other numbers out of wack??.
    Dan
    Sta-Rite 1HP Pump
    Circupool RJ-45 SWG
    TF100 Test Kit
    30,419
    Address it after your pool is shocked, crystal clear, and everything is in balance.
    1. Shock your Pool - do so according to pool school - it is a process not a one-time dose Do this ASAP
    2. Once the process is complete, adjust CYA to around 40-50ppm
    3. Repost your test results and the condition of your water
    4. Adjust TA if necessary
    Jun 2011
    11
    Okay, here we are 8 days later and what a difference in he pool's condition.
    FC- 7
    CC-0
    TC - 7
    PH - 7.6
    CYA - 50
    TA - 230
    CH - 300
    Temp - 78 deg
    Just coming off a shock, passed the overnight free chlorine test at .5 FC, and the pool looks beautiful.
    What should I do next to complete the balance of the pool?? Should I attempt to lower the TA?? If so, how far down should I lower it and any recommended steps??
    This forum is really great. After thirty-two years with a pool, I never understood and was always baffeled with water chemistry, always depending on the pool store for advise, but never understanding it. Your advise has certainly changed my mind and the proof has certainly been in the current results.
    GREAT JOB!!
    Dan
    Sta-Rite 1HP Pump
    Circupool RJ-45 SWG
    TF100 Test Kit
    30,419
    GREAT JOB!!
    Actually, that kudos goes to you. The forum provides the info and the methods. Pool owners like you take that info and take charge of their pools and get them sparkling....congrats!
    Yeah, now it's time to work on the TA. There's still no hurry to get it done tonight so read carefully on how to do it in Pool School. It's an alternating-step process of lowering pH with muriatic (the TA will come down, too) and then using aeration to bring the pH back up (the TA will stay down)
    There's a specific article in Pool School and it may take you a few days to get it down around 100 or so. Post back if you have questions after reading the article.
