Thread: Actual pool volume/gallons
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    I've found several sources to calculate pool volume in gallons. Seems my 15x30x4' pool equals 10,500 gallons. (??) Two questions please.
    The pool wall side is 48" (4') but the actual depth is 44". do I calculate by the wall size?
    According to "The Pool Calculator" my actual volume is 12,000 gallons, which figure should I use?
    Thanks everyone,
    Ed
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Feb 2008
    Denton, TX
    5,061
    Re: Actual pool volume/gallons
    You want to calculate using the actual depth of the water.
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    So is my pool's volume 10,800?
    30' L
    15' W
    44" D oval above ground pool.
    10,800 gallons
    TF-100 Test Kit
