Thread: hayward H400IDL Heater problems
    Hello everyone! I'm having some issues with my heater. When I first got the house it did not work properly and with a couple of home warranty fixes and then a self fix it was fine. Then last week it would heat the pool to 98 or so and then showed the "AO" code. I replaced the vacuum blower switch and then tried to turn it on and nothing happened. I think the blower may be the issue now, previous to the ao code it was getting very hot. Now, I. Can hear various clicks and things when I turn the heater on but no blower, I did notice that after leaving it on for a few minutes the blower motor was getting warm. Once today it also flashed an "LO" code, for the blower switch open/closed. I have read various post with similar problems on same heater and it seems like they never post a resolution. I plan to call hayward tech support on Monday but just wanted to see if anyone here has some experience with this.
    Thanks
    Chris
    -9000 Plaster IGP and attached spa with 4 jets , Hayward H400IDL NG heater, Hayward swimclear 4025 cart filter, Hayward superII 2hp pump, Goldline controls ps-8 controler with T-cell 15, Caretaker 99 in-floor cleaner and polaris in-ground leafetrapper.
    Feb 2008
    Denton, TX
    5,061
    Re: hayward H400IDL Heater problems
    Welcome to TFP!
    I don't have an answer for you, but someone who does will check by soon to help you out.
    I decided to take the blower motor off to inspect bofre i purchased a new one, Hayward Tech support was no help! Im am going to say it's safe to say that by the look of these pictures I took that I am better off buying a new heater!?
    More pictures
