Results 1 to 8 of 8
Thread: Ph climbing
    Bobbystone
    Guest
    Ph climbing
    Hey guys,
    My ph seems to climb rapidly. I have to add acid nearly every other day. CL is normal is there somehthingn I can do to slow down the ph climb?
    Thanks.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Ph climbing
    TA is likely to high. You can also add borates to slow PH rise.
    Re: Ph climbing
    Please post a full set of water test results.
    Bobbystone
    Guest
    Re: Ph climbing
    Thanks guys, Here's my readings:
    CL = 2.5
    PH 8.0
    TA = 80
    CH = 330
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Ph climbing
    How old is your pool? Got water features? Lotsa' kids swimming?
    The SWG will naturally push up the pH, as will new plaster, water features like watefalls, and any form of aeration, like a bunch of kids.
    Each time your pH reaches 7.8, lower it to about 7.4, for a SWG.
    If, however, you want to lower your TA to maybe 70 or 60 to see if that helps, follow the instructions in Pool School.
    Don't let your pH go over 7.8.
    You're done SLAMing when:
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Ph climbing
    How many returns do you have?
    Luv& Luk
    -Ted
    Bobbystone
    Guest
    Re: Ph climbing
    I have two skimmers and two eyeballs. The pool doesn't get a lot of use.. No kids yet! No water features, just a plain simple pool.
    Mar 2007
    4,160
    Re: Ph climbing
    With only 2 returns, you're going to see the hydrogen bubbles from the SWCG coming out of the returns. The concentration of the bubbles will tend to raise the pH. Muriatic acid will soon become your good friend As you get used to how your pool chemistry now works, you'll find that you need to add X oz. of MA every X days to keep the pH in line.
    If the pool has new plaster, that can also cause a pH rise for ~ the first year.
    Luv& Luk
    -Ted
