Thread: Polaris 380 problems...
    Hello, I have a polaris 380, it has been in my pool for 15 years and the right side shell piece if coming off. (It is the 1997 model with
    a two piece top shell.) I have replaced the shell screw recently and the shell piece that was loose as well, but the piece is still very loose. when I attempt to pull it out of the water the shell comes right off. I am sure the bottom base is causing the problem. it could be that the screw hole in the bottom base had warped or the hole was reamed. What should I do.
    -The pool vac guru
    Re: Polaris 380 problems...
    If you find that the screw hole is warped or partially reamed, try Teflon TAPE on the screw before reattaching. This might allow the screw to hold. You'll need to check it regularly since Teflon is meant to be a non-stick material and the screw might come lose. If the Teflon works but it doesn't hold long term, you could try some other type of tape. If the threads in the hole are gone, then the screw will have nothing to hold on to. Call and talk to the local pool supply store. I trust my store and they check out my cleaner for free.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Pool vac guru, it maybe time to look into a rebuild kit in the up coming off season. After rebuilding it will look like new!
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
