Thread: caulk at coping-deck
    Mar 2009
    Charlotte, NC
    539
    I have come to love silicone caulk.
    Is there any reason I can't use it at the coping-deck junction- see photo & see product info.
    (This would be sooo much easier than deck-o-seal & I' bet it wouldf last way longer if not forever)
    http://www.homedepot.ca/product/ge-sili ... -ml/941922
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Mar 2009
    Charlotte, NC
    539
    Re: caulk at coping-deck
    LeeM2 has my permission to ask questions, post his photos etc in this thread about his pool that lacks any caulk whatsoever at this area, we've been chatting about it.
    Jul 2011
    Northern NJ
    92
    I have had very good luck with Sikaflex® Self-Leveling Sealant from Sika. I find it at Home Depot in the concrete/cement supply area. They also have backing rod as well. The cost is far less than any other option I've found.
    IMO silicone is not suited for this environment and is inferior to the SIKA product.
    Anthony Pool, 35k gal plaster, DE (1.5hp Ultraflow), Rainbow 320, Dolphin Diagnostic 2001 (Advantage) & Polaris, Retrofitted Anthony mod #20 120v Niche light with Pentair 5G & adapter ring, 70's build / recoped and plastered 1.5 years ago
