Thread: Anybody here use flex pvc?
    Seems like every time I have a leak in my piping, either between my pump and filter or filter and return, I have to try a couple times to get my pvc piping to fit right. I thought about next time using flex pvc or the flex tubing stuff that you see used on the cheap above ground pools you can buy from WalMart. Anyone use the flex pvc or flexible "tubing" and how well has it worked for you?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Anybody here use flex pvc?
    Flex PVC is great, but it's not really flexible enough to do what you want. The best thing to do is to use PVC threaded unions at all the points where you may have to make a change.
