Results 1 to 8 of 8
Thread: non stop plumes of sand shooting in pool. party tmmrw
    every time i turn the pump on giant plumes of sand shoot into the pool. what do i do. im gonna sifon the sand the sand from the bottom but what do i do about the filter.
    24' X 52" round above ground pool---13,500 gallons---Hayward power flow matrix 1.5 hp pump---Hayward 21 in. variflow XL sandfilter---Louisville, Ky
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: non stop plumes of sand shooting in pool. party tmmrw
    You may have a broken lateral...hard to tell unless you take it apart.
    so should i take the sand filter apart and check it out. and get back with you. i will say that the very first time i turned the pump on this year (yesterday) a small plume of sand went into the pool and that was it. then i tried to vacuum the sand up witch clogged the pump (just now fixed that) and now every time i turn on the pump sand blows in. i will get back with ya when i take the sand filter apart.
    I took it apart and there is a large crack going all the way down the long vertical piece going into the sand filter!
    22,553
    You'll need to replace that then. I bet that solves your problem.
    yeah im gonna take all the sand out and replace the lateral and put in new sand. seems like an easy fix!!
    well i thought i could just buy the lateral (pipe piece). evidently you have to buy the whole assembly. now i gotta spend $70 bucks on the darned thing. never ending. pretty sonn there wont be anything to replace .....LOL
    22,553
    Kinda like fixing something on your car. One thing leads to another, leads to another, leads to another.... Now you're making me sad!
    Once you get it all replaced/repaired then it'll be smooth sailing.
