Results 1 to 11 of 11
Thread: Help - added Shock and my pool turned GREEN
    Poolkim's Avatar
    Jun 2011
    Canton, Michigan
    8
    Hi
    My Levels were as follows this morning:
    FC = 0
    PH = 7.6
    CYA = 75
    Water was cloudy, could not see the bottom. FC had been zero for over 24 hours and the cloudiness was only getting worse, even though I was running my SWG at 100%. I took a cup of water to the local pool store and they told me that my levels looked good except the FC = 0, just like I thought. I added 4 Gallons of shock per there instructions, within 1 hour my pool turned from cloudy to green cloudy? Why would adding shock make my pool turn green? I called the pool store they said my pool was probably already on the verge of turning green. They said wait an hour or so and it'll start to get better.
    Any advice?
    9800 Gallons IG Fiberglass
    Cartridge Jandy CT100
    SWG Jandy Apure700
    Max HP pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Help - added Shock and my pool turned GREEN
    Welcome to TFP.
    It should turn grey/milky cloudy soon. If it does not, it may be possible you have copper in your water along with the algae...but let the chlorine do it's thing. 4 Gallons of 12% chlorinating liquid, would have raised you FC by about 45-50ppm, which is high....30 is your shock level with CYA at 75...but don;t be too alarmed it will come down pretty fast.
    Having your own test kit is really handy when trying to shock your pool. Shock is a process, not a product
    Poolkim's Avatar
    Jun 2011
    Canton, Michigan
    8
    Hi Mod Squad,
    I have the TF-100 test kit. What should I test?
    Thanks!
    SWG Jandy Apure700
    Max HP pump
    Poolkim's Avatar
    Jun 2011
    Canton, Michigan
    8
    Forgive my ignorance... but is it ok to put my arm / hand in the water to get a sample so I can test it after I shock my water?
    SWG Jandy Apure700
    Max HP pump
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Yes... but rinse it off.
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Posting up a full set of test results is always helpful
    FC
    CC
    PH
    TA
    CH
    CYA
    The TF100 or most other kits do not test for metals. But before we jump to that conclusion...let see what your levels are and if the green fades over the next 24hrs
    Poolkim's Avatar
    Jun 2011
    Canton, Michigan
    8
    As of 3pm (3 hours after shocking)
    FC = 4PPM (where is the chlorine going?)
    CC = 0.5 PPM
    PH = 6.8
    TA = 130
    CH = 200
    CYA = 30
    CYA is low... should I add something to get that back up? Why/how is the FC so low already... I just added 4 gallons of chlorine 3 hours ago?
    Help!
    SWG Jandy Apure700
    Max HP pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by Poolkim
    CC = 0.5 PPM
    PH = 6.8
    TA = 130
    CH = 200
    CYA = 30
    Help!
    No, no, no! That CYA is perfect for shocking.
    The chlorine is gone because it's been killing algae. You need to give it some reinforcement - add some more bleach! If you don't, the algae will return, and those four gallons you poured in died for nothing.
    And I'm not sure I trust that pH number - that's very acidic!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Adjust PH to at least 7.2 and follow the instructions in the attached
    pool-school/shocking_your_pool
    Poolkim's Avatar
    Jun 2011
    Canton, Michigan
    8
    Thanks for the help! The pool is coming along now. It's mostly blue and I can see the bottom. Still a little cloudy. I'm still working to get the CC under 1ppm. Just gave it another shock now. I'm getting more confident everyday! Thanks for all the help.
    SWG Jandy Apure700
    Max HP pump
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
