Thread: plumbing inlet height for intelliflow pump
    May 2011
    No. CA
    111
    I've found the install manual and there are dimensions, but not the key one I need.
    Trying to see how much difference it is from my current pump.
    Pool IG 17,000 gallon (33 x 16) Spa IG 700 gallon - under renovation
    Sta-Rite IntelliPro VS 3050, Pentair Easy Touch 8, Intellichlor IC40, Pentair FNS Plus 60, TF-100 Test Kit w/ salt test
    Pentair Intellibrite 5G Color LED, Polaris 360, Lars Lx400 NatGas heater, Fafco Solar panels
    Mar 2010
    "Lamorinda" California
    52
    Re: plumbing inlet height for intelliflow pump
    Quote Originally Posted by Dan-H
    Yeah, Pentair has a problem documenting this pump.
    Here's what I found:
    - suction face to midpoint of discharge = 10"
    - floor to midpoint of suction face = 9"
    - floor to discharge face = 11 1/2"
    Good luck.
    ~29K gal, 20'x36' rectangular, outdoor IG plaster, built in '74. Intelliflo VF; Sta-rite system 3 w/300sq ft. Liquidator 8Gal-3/8ug; Polaris 380 sweep & PB4 booster. Equip. is in shed on ground level pad.
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    416
    Also note that the suction and return fittings are FEMALE pipe threads (FPT). I just switched one out for a friend that had a Sta-Rite pump that had Male pipe threads at the pump.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    May 2011
    No. CA
    111
    so much for an easy first stage of my upgrade :sigh:
    Looks like I will be re plumbing *everything*
