Thread: RAIN!!
    Guest
    RAIN!!
    I has rained very had for the past few days, my skimmer cover has a round hole in the top about the size of a quater and the pool is so full water is literally shooting out of that hole in the skimmer cover several inches into the air and createing a small lake/mud pit on the side of the pool. I took the plug out of my filter and jammed a vaccum hose into it to drain the pool faster and away from the pool. Is this going to drastically screw up my FC, PH etc?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: RAIN!!
    Probably not much. Figure out how many inches of rain you got and what the average depth of your pool is, and you'll be able to estimate a percentage loss of FC, CYA, TA, and CH.
    May 2011
    British Virgin Islands
    22
    Re: RAIN!!
    I have a similar question if anyone is still looking at this question.
    I have a few pools i clean in the British Virgin Islands. Usually rain isn't an issue, but rather evaporation due to the climate. However, we do get rain and it usually comes in two forms - its either mist like which doesn't really wet anything or its like a major storm for several days. All the pools overflow and i have a lot of water loss from contining rain and then from having to drop the level back to the correct level.
    I've seen a definate drop in chemistry due to it. Is there anything you can do to keep the chemicals in the pool or is it just part and parcel of having a pool and i need keep a good stock of chemicals etc for these times.
    Thanks
    Regards
    Andrew
    British Virgin Islands, Caribbean.
    Freeform pools - 12,000 gallons
    DE Filter
    In Ground Pool
    Pump Info to follow
    Richard320's Avatar
    Jan 2010
    19,051
    Re: RAIN!!
    The only way to keep the chemicals in the pool is to keep the rain out. I can't think of any practical way to do that.
    May 2011
    22
    Re: RAIN!!
    Thought as much, but from hints and tips for all kinds of stuff i've seen on here thought it might have been worth asking.
    Thanks for the speedy reply as always.
    Regards
    Andrew
    DE Filter
    In Ground Pool
    Pump Info to follow
