Thread: algae spots forming
    algae spots forming
    Hi this is my first post here: great site! Just used my new tf100 kit today & here are the results - fc-7.5 ,cc - 0, tc - 7.5, ph - 7.5, t/a 140 , ch - 40, cya - 60, temp 80f. I initially shocked with 24 gallons bleach 6%. I added 1qt leslies algae control on the 5th day after running the pump 24/7 to clear the green water up. 2 days later used 2.5 pounds leslie chlor brite which i have 40 pounds of for the season. I am using 3 3" tabs leslies in my offline chlorinator at full. I need advice for the next step since algae spots r forming in various areas of the floor around the pool. thanks in advance. Btw pool is a fox lazy l approx 25k i believe,fox sand filter which i changed the sand last season, hayward 1hp pump.
    Inground vinyl liner, 1hp Hayward super pump, sand filter. 20,000 gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: algae spots forming
    [centernh40kqc][attachment=0nh40kqc]nipit.jpg[/attachmentnh40kqc][/centernh40kqc]
    Your CYA is already getting up to where shocking is going to be difficult. Stop using that chlor-brite and those pucks if they have CYA, which I think they do.
    And it's time to shock, the right way. It's not a one-time blast, but a process.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Richard
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    Leslie's Chlor-Brite is Dichlor where for every 10 ppm Free Chlorine (FC) it also increases Cyanuric Acid (CYA) by 9 ppm. The tablets are Trichlor where for every 10 ppm FC they also increase CYA by 6 ppm.
