Pool Cover taken off 5-28-11
Got Sand Filter running and vacuumed pool.
Pool was green and pond looking.
12 hours later added 40 ozs of Green Out with 4 lbs of granular shock it.
Ph was high don't know exact at this point.
Added 40 ozs of ph Down (Aqua Chem)
5-29-11
Added 20 ozs ph down
Added some more shock it 2lbs
5-31-11
Took sample to pool store:
Fc/Tc: .6/5.6
pH 10
TA 70
CH 200
CYN 40
Suggestions from pool store:
Add 12 lbs sodium bicarbonate- Wait 30 mins
Add ¾ gallon of Muriatic acid-Wait 1 Hr
Add 10 lbs of Granular chlorine Brush pool
Add 10 lbs of Granular chlorine Brush Pool
Bring sample back Wed 6-1-11
I took sample back on 6-2-11
Fc/Tc: 14/14
pH: 7.6
TA: 80
CH: 175
CYN: 70
Phos: 500 ppb
Pool store suggestions:
Make sure pool is pulling from both main drain and skimmer.
Balance is OK but Phos is getting high. If pool does not get clearer in 48
Hrs, we will need to floc the pool and add a borate
Waited 48 hrs back to pool store on 6-4-11
Fc/Tc: 4/4
pH: 7.4
TA:60
CH: 200
CYN: 40
Phos: 500
Add 12 lbs of sodium bicarbonates-wait 1 hr
Add 16 ozs of phosphate remover (Sea Klear) wait 24 hrs
Add 10 ozs of polysheen blue (biochem)
Where I am now is a white particle which I assume is algae floating in the pool.
Pool color is Blue and measurables are pretty good, do I need to floc out the particles
so they will fall out to be vacuumed? Really seems to be the only thing keeping pool from
being right. Help would be really appreciated, I am confused on what to do next.
Thanks
5-29-11
5-31-11
Fc/Tc: .6/5.6
pH 10
TA 70
CH 200
CYN 40
Fc/Tc: 14/14
pH: 7.6
TA: 80
CH: 175
CYN: 70
Phos: 500 ppb
Fc/Tc: 4/4
pH: 7.4
TA:60
CH: 200
CYN: 40
Phos: 500
Thanks
