Thread: gray mucus stuff on filter
    I took my cartridge filter out this morning to clean it and it was COVERED in a gray mucus...any idea what that could be?? Could this be what is causing my water to be cloudy? I sprayed with the high pressure nozzle on my water hose but am wondering if I need to use the chemical filter cleaner on it again ( I just used it about a week ago). I would hate to ruin my filter.
    24' Round
    Above Ground
    Sand Filter
    1.5 HP Pump
    Re: gray mucus stuff on filter
    I know here in my area we have cotton wood in the air and it is attracted to my pool. It looks it is so gross and slimy when it get in the filter.
    17K gal, AG, Hayward Sandfilter, new to the BBB method.
    30,403
    A full set of test results will keep us from simply guessing but, once posted, those test results will almost surely tell us the pool is lacking/has lacked in adequate chlorine.
    Be prepared to shock the pool according to the SPECIFIC directions in Pool School but post the numbers up first.
    Woodberg's Avatar
    Apr 2009
    Houston, TX (Candlelight Estates)
    136
    I would concur with the cottonwood suggestion. We've got cottonwood's behind our house and in the spring, it definitely looks like you described. It hard to even get out of the skimmer baskets. I usually have to clean my filter twice in the spring to get it all cleaned out. Its just about over this year.
    BTW, the spanish word for cottonwood is Alamo. The Alamo in San Antonio had large stands of cottonwood's surrounding it which is where it got its name. I just thought that was interesting.
    20,000 gallon gunite pool, attached spa, Pebblesheen finish, Paramount PCC-2000 infloor cleaning system, Paramount ClearO3 ozone system, Intelliflo VS main pump, Whisperflo 1HP cleaner pump, StaRite cartridge filter, StaRite heater
    Feb 2008
    Denton, TX
    5,061
    I have had the same before. I attributed it oils from tanning oils and sunblock with other particulate waste mixed in.
    <---shrugs
    Feb 2008
    Denton, TX
    5,061
    Cottonwoods are pollinating heavily right now though.
