water is nice and clear
filix
149
maine
Been swimming for three days. I have learned to keep the solar cover off on sunny days, so the water will get warm. My ph is around 7.3 FC is 4 and CC is .5 so TC is 4.5 if I have this right. CYA is a little more than 40. I have a small air leak that Ted "waste" found. I will fix it next year. One question is with this air leak shooting bubbles out of the eyeballs, will this effect ph? thanks filix.
Probably not much at all but it REALLY affects the efficiency of your pump if it's coming from an air leak. I would make some plans to fix it. What is your psi?
