Thread: Best way to plumb inlet at pump Pentair Intelliflo FPT
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    420
    I have a Sta-Rite Intellipro pump which is basically a Black Pentair Intelliflo.
    I think I may have a tiny leak at the fitting connecting to the Pump Inlet. Currently it's plumbed with a Male 2" adaptor and then a few inches then a 2" Slip Union. It is too close to attach a male/slip union directly to the pump.
    Anyway would using a Schedule 80 Male adapter be a better set up Vs Schedule 40, This is the second time I have had a small leak here.
    Any ideas would be appreciated.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    Re: Best way to plumb inlet at pump Pentair Intelliflo FPT
    I would use a 2-inch schedule 80 cpvc nipple, which can go into the slip union. The cpvc will not shrink or deform under thermal or physical stress. I would use Permatex No. 2 for the sealant (not Teflon tape). If the nipple is threaded on both ends, then you can get 2 by cutting it in half.
    http://www.reliablepoolsolutions.com/2- ... lasco.html
    http://www.saltwaterpoolparts.com/nip-c ... -060c.html
    http://www.permatex.com/products/automo ... ealant.htm
    Support the site
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    420
    Yea thats what I was thinking... it seems like the Schedule 40 connector going into the pump seems to go bad- maybe from pressure- priming pressure and hot tub heat over time. And the teflon tape does nothing here..
    Will go to schedule 80 CPVC for the connections.
    ColorQ Pro
    TF-100
