Thread: barracuda G3 comes apart
    after our barracuda G3 runs for about 3 hrs, the main interior 'pipe' that screws in, near where the hose attaches, comes completely out of the housing. I pull up on the hose, and all I get at the surface is the interior 'pipe' of the unit. The main body of the unit is left at the bottom of the pool.
    anyone ever had this before?
    I have good suction, and good movement/pulsating on the barracuda; it just falls apart. It just started this a few days ago; no valves were altered at the pump.
    thanks,
    Feb 2008
    Denton, TX
    5,061
    Re: barracuda G3 comes apart
    I have never had that problem. You aren't missing a part are you. There is a little ring that you tighten down where the hose enters the unit. Is that tight?
    this was the problem; the ring where the hose attaches was loose. Tightened it and havn't had a prob. since.
    Feb 2008
    Denton, TX
    5,061
    The good thing about these suction side cleaners is that they have few moving parts, if any. It's usually a fairly easy fix or simple part replacement to get them back online.
