Thread: salt demand question
    I converted to a Hayward SWG when I opened this spring. I put 800lb of salt which got my salt level up to about 3400. Well, my pool's been up and running for a month now and my salt level is down to 2700 which is the lower end of the recommended range.
    Is the salt level dropping faster than I should expect?
    For the past few years I've thought that I was adding water a little too often. If I don't have a rain I have to add about 3" of water every 3-4 days so I guess I could have a leak somewhere. I haven't done the bucket test to see if the levels drop the same. I did have the liner replaced last spring which didn't seem to change the water requirement and I don't see any obvious wet spots.
    Any suggestions?
    40'x20' IG vinyl, ~30k gal. pentair triton II sand filter. 3/4hp Hayward Super Pump. TF-100 test kit.
    30,431
    Re: salt demand question
    Where do you live? That drop could be normal for AZ but unusual for PA.
    22,553
    Do the bucket test. 1" of evaporation a day is a lot!
    If your leak is in the plumbing then replacing the liner wouldn't help that at all.
    I'll do the bucket test tomorrow but I'm sure I'll have a leak somewhere in the plumbing. What can be done about it? Is it worth digging up all the plumbing to find the leak when its not obvious where its coming from. Is there something I can put in there to plug it up without digging it up?
    I'm in the Triad area of NC. My liner needed to be anyway so the possible leak wasn't the reason I did that.
    22,553
    If you're losing an inch a day then at some point it becomes enough to warrant fixing the leak, unless your water and chemicals are free. Once you do the bucket test we can help you narrow down the location of the leak.
    been having alot of hot days and rainshowers in the afternoon. It looks like I lost about 1/4" more from the pool than the bucket the best I can tell. My water is free as I'm on a well.
