Results 1 to 9 of 9
Thread: couldnt stay away from pool store
    New to BBB this year, due the the great knowledge available here my pool is looking spectacular..I had to go to the pool store to have a cya test( i have no test left) and to laugh at their recommendations. They wanted me to add 31 pounds of their optimizer plus lol.
    tc 5 ph 7.8 ta 150 cya 33 whats the best way to raise cya to 50 i have cynuric acid and trichlor tabs available. also how about ph should i lower it to lower ta or what. it was down to 7.2 and aerated to 7.6 then jumped up a bit after having a pool full of kids. any help appreciated thank you tfp.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: couldnt stay away from pool store
    The straight CYA will raise the level faster, and more precisely. Then you can save the tablets for vacation.
    whats the best way to add it. i have a cartridge filter
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Put it in a sock, either hang it in front of the return or you can put the sock in the skimmer as long as it is running the whole time. I tye mine to a chunk of pool noodle and let it float around.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    Quote Originally Posted by NWMNMom
    An EXCELLENT idea ... putting that one in my memory bank!!
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
    Apr 2011
    Somewhere on the Emerald Coast
    156
    From a post I made about 6 weeks ago ... HTH
    I used an old "boot sock" - one that I used when hiking (its "mate" developed a hole in the toe so my wife pronounced the pair "dead") ... but I digress ...
    I initially hung the CYA laden sock near the deep end ladder - it was still in the circulation pattern and "out of the way", but I noticed it wasn't dissolving as quickly as I wanted (water doesn't flow out of the faucet fast enough either) - so I moved it to the skimmer basket. It took about 2 days to dissolve.
    My point is - the boot sock is a very heavy weave - yet very porus - so placing it into the skimmer with the additional flow seemed to dissolve the CYA much quicker than just hanging it off the ladder. None of the particles get hung up in the filter when pouring it straight into the skimmer and they don't settle to the bottom if broadcast dispersion is used.
    I'm still kinda green with the BBB method and I'm learning every day from all the great posts here - just sharing my new observations. HTH !!!
    Mike
    NWMNMom - That's a great idea. I have a noodle that's close to the end of it's "life" and I think I know what it's afterlife will be!
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    For TA:
    My method may be a little less orthadox. I like to maintain my TA indirectly. I do not really worry about the numbers, or chase the "ideal" number. Instead, I just monitor pH.
    If I am having poblems with my pH bouncing around too much, I will calm it down with some nice... "soothing" baking soda.
    If my pH keeps rising... Well... I just keep knocking it down to about 7.2 with acid. The rising pH is a symptom of too high of TA, and the acid will lower the TA nicely.
    Eventually, things just hit a nice equalibrium where I don't have to worry that much about either pH OR TA.
    I do occasionally test my TA, along with my CH to make sure my CSI is in line. But as long as that's cool, the TA can be whatever number it feels like being.
    Old thread - I know.
    Wasky - I discovered this same thing you describe by experience and do this same thing exactly...
    Seems to work fine and it's quite easy!
    Choots
    Mar 2009
    eastern washington state
    275
    I just put my CYA in the skimmer and let it go to the filter and make sure i dont back flush for a few days.. Its the easiest for me. Seems to work.
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
