Thread: Adding Borax
    Adding Borax
    I am new to this BBB method...I need to increase my ph by adding Borax. How exactly to I add it? Through the skimmer or mix and pour in the water?
    FC-4
    CC .5
    PH- 7.2
    TA- 80
    Thanks for any help!
    17K gal, AG, Hayward Sandfilter, new to the BBB method.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Adding Borax
    Quote Originally Posted by randadawn77
    FC-4
    CC .5
    PH- 7.2
    TA- 80
    Borax is best added by pre-dissolving it in a bucket of water and then pouring that slowly in front of a return.
    Your pH of 7.2 looks fine. Why do you want to increase it?
    You're done SLAMing when:
