Thread: Questions about lowering TA
    Jun 2007
    Michigan
    16
    My TA numbers have been rising for the past 3 seasons starting out at 120 and now it is 210. So i am going to go threw the process of lowering
    with MA and aeration this weekend. I have a couple questions....
    1. How long after adding the acid is it safe for use? or is the acid diluted enough that it wont be unsafe?
    2. Is the aeration process something that i can work on a little every night, (with a pump from harbor freight and the kids splashing around) before shutting off the pump and putting on the solar cover for bedtime? Or will it require more constant attention?
    10k AG Chois Pool
    Sand Filter
    Royal Entrance Stairs
    Sep 2009
    Greentown, IN
    914
    Re: Questions about lowering TA
    I think I recall that you should wait at least 30 mins or more before swimming just to give the chemical a chance to disperse and dilute... with the pump running of course.
    You can do it bit by bit... not something that needs constant attention like shocking.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jun 2007
    Michigan
    16
    Thanks for you help
    10k AG Chois Pool
    Sand Filter
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Also on your last Q...As long as the PH is 7.2 or above, you can swim...otherwise you need to aerate to raise PH to at least 7.2
    Jun 2007
    Michigan
    16
    Thank you both
    10k AG Chois Pool
    Sand Filter
