Thread: got my new test kit....now what?
    I just got my T-F100 test kit and have taken my first analysis. Now what do I need to do? Is there a chart somewhere that I reference to know what to add and how much?
    My results:
    FC=0
    CC=.5
    Ph=7.2
    TA=50
    CYA= less than 20ppm
    my water is cloudy....just opened 1 week ago and have been waiting to add anything until I got my test kit.
    Any help would be greatly appreciated.
    I am new to the BBB method.
    27 foot above ground
    sand filter
    Hayward 1.5hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,025
    Re: got my new test kit....now what?
    Head on over to Pool School and do a little reading.. especially on Recommended Levels, Pool Calculator, and How to shock your pool.
    Between the primo test kit and Pool Calculator, you might just be swimming before the weekend's over!
    Welcome to TFP!
    If you know what you want to adjust you can use the Pool Calculator to tell you how much of which chemical to use to make the adjustment.
    The first step is to shock the pool, after you start shocking you should add about 30 ppm of CYA. For details on shocking, see How to Shock Your Pool.
