Thread: Stenner pump/tank specs
    Jun 2011
    Oakdale, CT
    16
    I'm thinking about buying a chlorine injector. I'm just not certain about my requirements for a 24k gal in-ground pool (ie which pump to buy and what size tank). Where is a good place to purchase?
    24,000 gal, in-ground, vinyl, hayward de filter, automatic chlorinator with tricolor tabs
    22,541
    Re: Stenner pump/tank specs
    You can search for Stenner pumps and find several places. The best price I found was USWaterSystems.
    How long do you run your pump each day?
    What's your normal FC loss each day?
    On a 24k gallon pool losing 4 ppm per day you'll need to add 1½ gallons per day of 6% chlorine. if you run your pump 8 hours a day you'll need a pump that will deliver 5 gpd. I'd probably go with a 10 gpd pump and a 15 gallon tank. You can either order the Stenner tank setup of just get the pump and order a 15 gallon drum from ebay or dudadiesel, etc.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
