Results 1 to 19 of 19
Thread: buying R-0871 regagent
    Diver's Avatar
    May 2011
    South of Boston
    450
    it's only 2 weeks into the season and i seem to running out of R-0871 (testing at shocking level uses too much of it and k-2006 has only .75 oz bottle in it). so i was looking online and there are 2oz bottles with drop snout and bigger ones without (16/32 oz).
    i looked at my bottle from the taylor k-2006 test kit to see if i can refill it and it seems like one can't open it. so 2 oz bottle might be the only choice for me. can that bottle be opened and refilled? does it make sense to buy 8 oz refill bottle?
    should storing in cold dark place provide enough shelf life for 16 oz bottle?
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    22,544
    Re: buying R-0871 regagent
    You should be able to open your .75oz bottle. Look the the base of the nozzle top and see won't it pry off?
    If you store it in a cold dark place it will last a good long time. I'd still only get the 8oz. Hopefully you don't plan on shocking being a regular thing.
    Diver's Avatar
    May 2011
    South of Boston
    450
    i looked and i didn't seem to notice it that the top comes off. maybe i didn't pay close attention
    2 oz cost about $11 and 16 oz costs about $19. doesn't seem that they sell 8oz refills.
    good to know i can refill my 0.75 bottle - this way i can still have it in the test kit box.
    thanks!
    Diver's Avatar
    May 2011
    South of Boston
    450
    is there any difference between R-0871-C-12 and R-0871-C?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by Diver
    Yes.
    -12 is a 12pack
    Diver's Avatar
    May 2011
    South of Boston
    450
    Quote Originally Posted by Richard320
    Yes.
    -12 is a 12pack
    then this is a bad business model (from http://www.national-pool-care.com):
    Diver's Avatar
    May 2011
    South of Boston
    450
    i did check and it doesn't seem to be the price per item when you buy 12. r-0871-c and c-12 pages are identical, except the first one weight 0.18lbs and the second is 0.1833lbs
    Richard320's Avatar
    Jan 2010
    18,984
    From Taylor
    Reagent Size Code Explanation
    A = .75 oz (22 mL), A-24 = .75 oz (24 pack), A144 = .75 oz (144 pack), B = 2 oz (60 mL, wide-mouth),
    C = 2 oz (60 mL), C-12 = 2 oz (12 pack), D = 4 oz, DD = 8 oz, DB = dropper bottle, E = 16 oz, F = 32 oz,
    F4 = 32 oz (4 pack), G = gal, G4 = gal (4 pack), H = 25 g, I = 10 g, II = 50 g, J = .25 lb, K = 1 lb,
    Z = 1,000 pack, Z-10 = 10,000 pack, Z-50 = 50,000 pack
    http://www.taylortechnologies.com/produ ... ing=R-0871
    Or just order it all from http://tftestkits.net
    Diver's Avatar
    May 2011
    South of Boston
    450
    Richard, that's pretty good break down! Thank you for the info.
    you will probably get it much faster from tftestkits too!
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Mar 2007
    Coastalish 'down easter'
    4,160
    I won't buy my reagents nor test kits from any other source than http://www.tftestkits.net!!!!!!!!!!!! I know the reagents are fresh (good) and can really trust my testing! [also, the shipping is as fast as Speedy Gonzalez ] (Dave and Meg are THE BEST!!)
    Luv& Luk
    -Ted
    30,414
    (Thanks, Speedo and Waste. As we discussed, the checks will be mailed at the end of the month)
    I know, I haven't sent you my log of how many times I mentioned your site.
    (tonight when I get home I need to post up [in suggestions of course] the spinning Mr Green, I love it. I know I have it somewhere)
    Quote Originally Posted by waste
    also, the shipping is as fast as Speedy Gonzalez (Dave and Meg are THE BEST!!)
    Ok, I feel the need for more bragging. The shipping speed is fast!! But the supplier sending quickly makes an even bigger difference.
    Aaron
    Mar 2007
    4,160
    Re: speed and service
    I had Tuesday off so left the ordering of the 2 TF100XL kits to my boss. She didn't get the order in before 2:00, but, Meg still got them out that day
    They arrived yesterday!
    I swear, you CAN NOT go wrong by using TFtestkits
    Luv& Luk
    -Ted
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    I second that
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Jun 2011
    NW Florida
    57
    thanks!
    The tip of the bottle is a clear and the bottle is brown. Give it a pull and it will separate so that you can refill.
    Commercial,100 K, Liquid chlorine, Indoor, Heated to 86 with Jandy Lite 2 gas heater, High-Rate Sand Triton TR-100 filters (3), 7.5 HP pump motor, IG, Plaster.
    Jesus is my Lifeguard!
    Aug 2010
    Dallas, TX
    4,052
    I know the 2oz can be refilled too.
    I just had to break down and get 870 from Leslie's. Almost $10 for the same thing Dave has for less than $7. I have to have it today though. Darnit. I had my jar from TFTestKits with me in case I got someone that said "I have never heard of R-0870". When I showed it to her, she said "Where did you get THAT from?" LOL!
    Jun 2011
    NW Florida
    57
    Quote Originally Posted by salvationarmy
    thanks!
    I just practiced a little (I had never removed it before). If you grip the bottle in your palm and push away the tip with your thumb, it will come out easily.
    Diver's Avatar
    May 2011
    South of Boston
    450
    it does come out, but in the process you might end up squeezing the tip a bit too much affecting the size of the drops and accuracy of your tests. it did happened to me, so in the future i would keep it in the original bottle
