Results 1 to 10 of 10
Thread: TA of 440?
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    TA of 440?
    I tested the water in the pool that we had filled on Monday.
    All parameters tested fine, but the TA came out to be 440, did I make a mistake? Or is this something I can fix?
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Re: TA of 440?
    You should already know this but did you try wiping the dropper tip occasionally with a damp tissue while doing the test?
    Extremely high TA levels can be fixed but it takes work.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: TA of 440?
    ha! I know I should know, I went from a bromine pool that didn't take much work to this. I'll try redoing the test tonight. Last year my TA was 90, so it may have been operator error.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: TA of 440?
    I tested again last night, and still got in the high 400's. I'll run a sample down to the pool store, in case my reagents are bad.
    Re: TA of 440?
    If TA really is 400+, it is time to start the lowering TA process.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: TA of 440?
    Also, if the TA is really that high, then I'd expect your pH to be high unless you've got a pool cover.
    Re: TA of 440?
    Test your fill water from the tap to see what that shows.
    Support the site
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: TA of 440?
    The fill water came from a water truck. The pH is perfect and solid for the last few days at 7.5. I do have a cover, but it hasn't been installed yet.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: TA of 440?
    Here is my results from tf-100 June 7
    FC 8.5
    CC .5
    TC 9
    PH 7.5
    TA 440
    CH 170
    CYA 20 (assumed, added 1800 grams to fresh water)
    Salt: 3000
    Pool store June 10
    TC 5
    FC 5
    PH 7.8
    TA 150
    CH 110
    CYA 30
    Salt 2800
    TDS 3600 (weird)
    I'm adding some more cya to get me to 60-70.
    SWCG is running at level 2 or 3 and maintaining FC of 5. No bather load as I'm still waiting for temp. Currently at 70.
    I'm guessing my reagents are bad to get 2 TA readings over 400
    Re: TA of 440?
    It sure seems like it. With a SWG you would see huge PH drift if TA was really that high.
