Thread: level of water in "closed" pentair 320c
    Diver's Avatar
    May 2011
    South of Boston
    450
    i recently installed pentair 320c inline chlorinator. i haven't used yet and not plan on doing it until i have a need for it (vacation or required bump in CYA). so right now the switch on the chlorinator is in OFF position.
    when the water is flowing i see some water in it (i could post a pic tonight). it's maybe a quarter of an inch into the amber chamber, or probably about an inch in the chamber overall. but it's not always there and i can't figure out the circumstances that accompany it.
    right not it's not a problem, but if there is any tabs in it it will probably result in the tabs being dissolved and some ppms going into the pool. in the "OFF" position. the water in the chamber doesn't seem to have any flow it though.
    so, is it normal? does my valve is broken? is it a big deal?
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Diver's Avatar
    May 2011
    South of Boston
    450
    Re: level of water in "closed" pentair 320c
    here is the pic
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Bump
    Feb 2011
    Central Texas
    187
    Might be the valve. Mine shut completely off in the 'off' position. Also wonder if it could be the check valve letting some of the water from the return line in through the bottom.
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
    Diver's Avatar
    May 2011
    South of Boston
    450
    so sounds like there shouldn't be any water in the chlorinator in "off" position. which kinda sucks since it means that i have one of the valves (main or check) defective. i guess it's not a big deal since i'm not even using it and when i do it will be for specific amount of trichlor that would be gone after it's used up.
    thanks for answering
