Thread: Measuring Volume/Weight Help
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    At the risk of sounding like a moron, my first pool is up and I'm having a brain cramp on all these units of measurements for the chemicals: ounces, litres gallons, cups, quarts
    Can anyone guide me to an easy location to to sort all this out, or help break thru the fog in my brain?
    Do I need a little scale or something??
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Measuring Volume/Weight Help
    A measuring cup is all you need. Use the volume quantities. I personally use one of these:
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Hi Richard, I'm ok on the liquid volumes but it's the dry volumes that are putting my brain in knots, on top of everything I have to convert from voodoo Canadian metric.
    Do you mix your powers with water by any chance?
    Richard320's Avatar
    Jan 2010
    18,967
    Nope, powders are the same as liquids. Just make sure they're level. It's no different than measuring out flour or sugar. If you're working in metric, set pool calculator to metric units, up on the very top brown bar, far right. Then use a metric measuring cup; I'm assuming they make such things!
    Mar 2011
    Lower Bucks County,PA
    65
    http://www.onlineconversion.com/
    Maybe this can help.
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
