Results 1 to 10 of 10
Thread: Bread: even the pros use it
    nutjob's Avatar
    May 2011
    Dallas
    109
    When cleaning the filter basket of my water feature pump, I thought it was just normal for a bunch of water to come rushing out when popping the lid. I got pretty quick at it: pop, remove, replace, clean, pop, install, replace, done!
    But apparently that's not supposed to happen. It turns out my builder forgot to install a valve on the suction side of the pump that you can close.
    So their pro plumbers are out this morning adding such a valve. They came by with a variety of equipment:
    • Hack-saw[/*:m:1dqrym7m]
    • Valve[/*:m:1dqrym7m]
    • Lengths of PVC pipe[/*:m:1dqrym7m]
    • Primer[/*:m:1dqrym7m]
    • Cement[/*:m:1dqrym7m]
    • Swim goggles[/*:m:1dqrym7m]
    • and a loaf of white bread. [/*:m:1dqrym7m]
    One guy swam down, removed the main drain cover, and got busy with the bread while the other guys worked at the pad.
    Wow.
    I laugh—to disguise the tears.
    Size 15,000 gal 510′² | Filtration DE 48′² | Sanitation SWG+O₃ | Placement in-ground (IG) | Finish pebble
    Pumps Intelliflo VS+SVRS main WhisperFlo WF-28 feature | Location Dallas TX US (33ºN 97ºW)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Bread: even the pros use it
    Wonder Bread is best for plugging pipes. Very malleable, and the lack of fiber helps it dissolve and pass through when the work is done.
    I did a lot of copper plumbing when we remodelled a bathroom at the scout camp and was taught that trick. We needed the pipe to be dry to sweat on a new fitting. So, shut off the water, unsolder the existing or cut into it, pack it full of wonder bread and get to work. Turn of the water, open the tap, and little lumps of goo come out.
    Jul 2009
    London and France
    574
    Ditto, a handy little tip
    dorpo75's Avatar
    Jul 2009
    NE Ohio
    256
    And here I have been using it for toast and sandwiches all these years...
    2005 Dimension One Venture model 370 gal. hot tub. We'll be using the TFP method to keep it clean and ready to use!
    TFP - The Finest Phorum on the Net!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by dorpo75
    Me, too! I thought they were gonna talk about making 'mater sammiches
    You're done SLAMing when:
    Jun 2010
    San Antonio
    424
    I have used bread during installation of irrigation sprinkler pipe to keep dirt out. It works great - when you turn on the system it flushes all the bread out.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Mar 2011
    Houston, Texas
    413
    My system does not have this valve either. Each time I clean the filter basket most of the water runs out of the basket as well. I haven't worried about it thus far. When I turn the pump back on it takes a few seconds for the pump to prime (I always open the air valve on top of the filter until all of the air is gone), but it seems no worse for the wear. Should I be concerned?
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    nutjob's Avatar
    May 2011
    Dallas
    109
    Quote Originally Posted by HouTex
    I'd wager there's no real need for concern, save for saving on water.
    My equipment pad is a few feet lower in altitude than the top of the pool surface which means putting up with a LOT of water every time I opened the pumps' lids or the leaf catcher lid. It was really annoying, but the builder was willing to correct it for free, which is mainly why I went ahead and asked for it.
    (Meanwhile, I hope the number of bread particles floating around has gone down today!)
    Feb 2008
    Denton, TX
    5,061
    Heh heh!
    FormerPoolGuy's Avatar
    Jun 2011
    GUAM USA
    3
    Two ways to remedy this problem when pump system is below pool:
    1. Ball valve (open and close each time)
    2. Inline Check Valve (automatic) (as long as you orientate properly) This only happened once....I swear!
    Dan
    20' x 48" Intex Ultra Frame
    Intex 635t Filter/Pump, Intex SWG (Salt Water Gen) 54601WL
