Thread: volume discrepency
    Mar 2011
    Lower Bucks County,PA
    65
    volume discrepency
    Pool Calc #-7100 gal
    Volume Formula #-6255 gal
    HTH Test Calc #-6287 gal
    Where's the difference in gal's on a 12x24x3.7 oval ? I can accept the two but 845 is large. Is something else figured in with the Pool Calc # ??
    12X24 Oval AGP +/- 7100 gal
    Clearwater 100 cartridge filter
    Hi-Flo 2sp 1hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    Re: volume discrepency
    If it is essentially two 12' diameter half-circles separated by a 12' square, then 7100 is what I get. The other calculators may be assuming something shaped more like an ellipse, which would be expected if it was in-ground.[attachment=0:3q9do4l1]ovals.gif[/attachment:3q9do4l1]
    What Richard320 said (except that I know for sure).
    The difference has to do with what an "oval" is. The formula you are using and the HTH calculations assume an oval/ellipse as defined in geometry, everything rounded with no straight lines anywhere, while the Pool Calculator is assuming the common swimming pool oval, straight sides on the long sides with half circles on either end.
    Mar 2011
    65
    I figured it had to do with oval def. but if i didn't ask -i'd never know. Thanks.
    Hi-Flo 2sp 1hp pump
