Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Do I need a new ladder???(pic)
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Noticed this this spring. Pool installed 2009. Is this a common thing with ladders Is this putting metals in my water??? Thanks to TFP, I'm certain it is not because of my water chemistry. I did have a very small spot of cobalt staining last year, which was probably caused by CH of 120, which I fixed.
    I called the company who installed the pool and they said they did not warranty ladder rust. With all the trouble I had with them during my build, that really didn't surprise me
    Do I need to get a new ladder??
    Thanks folks
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    22,553
    Re: Do I need a new ladder???(pic)
    I don't think it's adding enough metals to be an issue for you but Id' get a new one. Either a good grade of stainless or a plastic encased one.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks Dave. If I replace it with a new SS, how do I know if it is a good quality SS ladder, unlike this one that came with my pool???
    If I went with the plastic encased one, seems the plastic would break down fairly quickly in a SWCG pool along with the sun exposure. What say you?????
    Lynn
    22,553
    Plastics designed specifically for pools or outdoor use are UV stabilized and don't break down like non-stabilized plastics do.
    A good grade of stainless will say what the grade is. (i.e. 304, 316L, etc.) You want either 316 or 317 grade for the best results and if they're "L" graded it's even better.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    You are the man Dave Thank you soooo much.
    Lynn
    Jun 2010
    San Antonio
    424
    Lynn, I have a plastic ladder made by Ultimate Manufacturing. It is several years old and was in the pool when I bought the house & pool. I have been very satisfied with it. The other day I broke one of the handrails. I Googled Ultimate pool ladders and found several retailers and the manufacturer. I called the manufacturer and they voluntarily offered to replace the handrail under warranty without charge to me. Their warranty is for 10 years. I tell you this because first of all I am pleased with the ladder and secondly I am extremely impressed with their service.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks Larry. That's great to know. I will check them out.
    Lynn
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    Orthofish, we have the same problem with our ladder too. Unfortunately we have some weird measurement from the side of the pool wall to where the ladder goes in on the deck. Last year we pulled the ladder out and used a rust remover. But of course wouldn't you know it, the rust is right back again. Looks like we may have to get one specially made because of the odd measurement. Thanks from me too, Larry. I think I'd like to go with a plastic encased one this time.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Jun 2010
    San Antonio
    424
    Mickey, I don't know if the Ultimate ladder will work for you or if they have a conversion kit that would make it work. If your interested you might give them a call. When I called I left a message and got a call back later the same day and the person I spoke to was very helpful. Just Google Ultimate Manufacturing and look for the one that makes pool ladders. If you can't find it you can PM me and I will locate the number I called.
    Larry in Texas
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    It appears Ultimate only makes ladders for AG pools. I have an IG. It looks like I will be getting a 304 grade ladder. I haven't seen any of the 316 or 317 online that specifically says 316 or 317, but I have a feeling they are going to be too expensive But then when I think about it, if I'm going to be buying a 304 grade every 2 years I should just suck it up and get a better grade
    I hope mine isn't an oddball one too Mickey. I had done a search for my problem and had read your thread about having the same thing.
    Lynn
    Jun 2010
    San Antonio
    424
    Lynn, Have you thought about steps. When I had an IG I had steps and was very happy with them. Don't know who made them. Based on my experience with Ultimate I would shoot them an email an make sure they do not have an IG solution. Although on their website I only saw AG ladders, so they may not. When I talked to them they did have some products that were not on the website, but they were for an AG as well.
    Larry in Texas
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Larry, I'm not sure what you mean by steps I think I just need to replace the ladder, if I don't run into the problem Mickey did. Mine appear to be pretty standard, but then I haven't done any measuring either.
    Lynn
    Jun 2010
    San Antonio
    424
    By steps I mean the wedding cake type that are advertised in the online pool catalogs. They are wider and a little more formal than just a ladder. More like a stair case or the built in stairs in some in-ground pools. All serve the same purpose it is just a matter of taste.
    Larry in Texas
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I have steps in the shallow end. The ladder is in the deep end. See pic from my install. My pool is a fiberglass inground.
    Lynn
    Jun 2010
    San Antonio
    424
    That is what I meant by steps and I understand why you want the ladder. Let us know what you end up doing.
    Larry in Texas
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Will do Larry
    Lynn
    Mar 2007
    Coastalish 'down easter'
    4,160
    Hey Lynn
    You got inferior quality S.S. on your ladder It usually takes a while to show up but a SWCG reveals the defect pretty quickly. I'd double check your warranty to see if there is some 'reasonable' fix. With the other issues you had on your build, the PB ought bend over backwards for you!
    Luv& Luk
    -Ted
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Hey Ted,
    I agree with you 100% on the trouble I had with this company. I called Family Leisure and the girl went and asked someone if the ladder was in warranty and came back and said it was not covered. Imagine that I don't know what else to do. I'm looking around the internet for a good ladder. Most of the ones I've seen state they are 304 grade or $300-500. I'm wondering what grade this one is suppose to be??
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Found out from the builder that it is a S.R. Smith ladder. Looked on their website and found this:
    This warranty specifically excludes fading of materials, microbiological staining of diving boards or pool slides and rust or corrosion of any metallic products or parts.
    The search for a new ladder continues
    Lynn
  20. Back To Top    #20
    22,553
    It's probably supposed to be 304 but it could be 302 or about any thing else. Or it could be just stainless plated. 304 should last a long time if you keep your levels correct. From your pics, yours looked like they were plated, and if you get a good solid 304 stainless ladder it should be fine. I still prefer a fully plastic encased ladder.
