Thread: chlorine added, then Pool Perfect added help..
    my pool was green so I added Chlorine last night, this morning my water is cloudy and my husband added Pool Perfect, before he left for work, can we still swim in it or what should I do?? This is our 2nd year as pool owners help! please and Thank you!
    midwest, 28ft round above ground pool, apprx 20,000 gallons, sand filter
    - Michelle in SE Michigan (suburban Detroit)
    54" Desert Spring Doughboy 21x41' oval AG pool, with 7' deep end on half the pool - approximately 23,000 gallons. Including 2 returns/skimmers/main drains, 300lb Doughboy sand filter, 2HP Doughboy pump.
    Re: chlorine added, then Pool Perfect added help..
    Welcome to TFP!
    Pool Perfect isn't required, nor is it likely to help, but it won't hurt anything.
    You shouldn't swim until the pool clears up and you are able to maintain appropriate FC levels.
    Without water test results, you need to do a lot of guessing. Did you add enough chlorine to kill all the algae? There is no way of knowing without either test results, or waiting a while to see what happens.
