Thread: Broken Drain Cover
    GTGallop's Avatar
    Aug 2008
    Cave Creek, AZ
    39
    Broken Drain Cover
    The drain cover for our pool finally gave up after 15 years in the sun, water, and chlorine. It looked pretty flimsy any way. I need to get it repaired ASAP. Any recommendations? Price?
    Here is what I know / think:
    There are 2
    It has a sump
    It is approx 8" diameter
    3rd Time Pool Owner - 2014 In Ground, Gunite/Pebbel-Tec, 24' long 10,000 Gallon, Chlorine, 2 Hp Hayward Ecostar with Cartridge.
    http://www.troublefreepool.com/my-on...le-t40734.html
    Cave Creek, Arizona
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Broken Drain Cover
    Jump in with a mask and screw driver. Look for replacement on line.
    GTGallop's Avatar
    Aug 2008
    Cave Creek, AZ
    39
    I got a much better universal-fit kit at a local shop for $32.00. I'm having difficulty getting the screws to go in though. Part of it is spending 70% of my energy fighting buoyancy (I'M FAT). And the other part is that I only stay down for about 45 to 60 seconds.
    I think the screws get enough bite but are so long it is taking extra time. If I cut them shorter or buy shorter ones they should do fine. Then it would take less time swimming down and turning the screws.
    But a weight belt and a LONG snorkel would be a big help!
    Cave Creek, Arizona
    GTGallop's Avatar
    Aug 2008
    Cave Creek, AZ
    39
    I might invest in a Kettle Ball Weight to put on the bottom while I'm working there. It would give me a handle to hang on to at the bottom. 20lbs should do the trick. Maybe 30...
    Cave Creek, Arizona
    GTGallop's Avatar
    Aug 2008
    Cave Creek, AZ
    39
    Well fudge! The screw holes stripped out and now I'm having to drill them out and fit a slightly larger screw in. All while under 5.5' of water and while treading water upside down.
    Cave Creek, Arizona
    Apr 2011
    Murrieta, CA
    2,360
    It's a little late, how about one size up (a little shorter) stainless steel wood screw.
